Decent cost on Avon Cobras
Why the enormous rip off in OZ?
It’s because of the ‘ Australia tax ‘. We are a distant island and at the importer’s mercy. No choice :-(
Ooooh, if you can feel any play in the front bearings... perhaps tightening them until you get your new set might be safer. It's a tricky procedure. I let my experienced tech Rick @ Pasadena BMW do that. I have no training or experience so count my advice in fractions of a penny.
I changed mine when the tubes came off the change the seals @ 50k miles on an 07 Classic. AllBalls make a cheap set. Upper and lower roller bearings and races.
The motion pro bead protectors are worthless they can’t take the force it needs to remove rear tire bead, they split real easy.
Buy all tires at rockymountainatv. I don't even look elsewhere anymore.
Remove wheels, cart to Honda/Suzuki shop, mount and balance $35.
All Suzuki shops can do the 240, just a tip (thanks M109).
Valid info. I take mine to the local Triumph/Suzuki shop. If they are to busy I use the local Honda shop.
The local T/S shop won't repair flats anymore. The local Honda shop will.
Since our local Triumph shop moved and changed management I have been using the local Honda shop mostly.
