40mmrrsmith
I love the beads. Tire guys that hate them are usually lazy monkeys. One Dealership I used, gave my wheel back with dynabeads stuck in the bead seating area and bearing area. Another one I used balanced the tire even after I told him the beads were enough. Well later when I went to cut a hole in the tire to recover and reuse the beads....no beads in the tire. I watched a tire shop guy pour the beads in the tire before he was about to mount it. I cut a hole in the old tire and recover the beads. Seat the new tire. Then just start to break the bead on one side, pour the beads in, air up the tire. To remove I cut the sidewalls all the way around parallel to the tread. Then the bead will tilt enough to facilitate removal.That rear tire will beat your butt big time. Wide wheel with little drop in the center. To get off the old tire, I had to cut the bead with a small cut-off wheel, being very careful not to touch the rim. I use Ride-on in all my bike tires. Balances and acts as a sealer too. Some tire guys hate the dyna beads when changing a tire, as they fall out everywhere and sometimes jam up the machine. At least that's what I was told.![]()
