cuts out and won't start in Neutral
Hi You may be on to something as fuel very low following a ride out. So will fill up tank you mention MAP
Hi you may be on to something the fuel is very low following a ride out. I will have a look at that tomorrow many thanks on your electronic logic. Good warp9.9
Last line read good warp9.9 asking DEcosse
low fuel unless you are actually running out and sucking air thru fuel pump and then it would also be doing it when in gear is not likely to be your issue, read my posts previous page the TPS Stepper motor Sync is responsible for most idle issues
Yes my Daytona does the something and you are correct it will not even turnover.
Mine was typo, meant to say doesn't start, frigging auto correct removed it and I obviously didn't douvle check before posting. Lmao. I've had an issue where it just clicks once then stop then click very strange but turned out the tune in the ecu was the culprit, how weird is that. @HansO I know you have sent me tunes before but can you send me another to suit a 2011 roadster with pods and reband exhaust it has 1 7/8 primary 3 into1 system on it. I need something to hold me over while I save for a dyno. I have a lot of decel pop when I backoff I'm running the 20355-2 map atm
I have read the posts regarding stepper motor and ECUtune etc very interesting and sounds a plan, however at this point I am in uncharted waters. I need to get up to speed or place this in the hands of someone who knows. Cheers.
Do you have TuneECU if not reach out to one of the other Brit's on here it is a free software and a $20 cable the single best investment you can make, the procedure takes very little time but is best to have an assistant to watch the 'putor for voltage changes while you are down adjusting the TPS or/and stepper adjustment as nessasary
resend me your e-mail address and I will do, no sweat
Thanks for your advice this going to be an interesting steep learning curve for me but as I intend to keep the R3R it's going to be worth it. Cheers
