this is for standard/classics not touring i am assuming that it will be the same
the starter relay is the the place to start to check voltages.
12 volts comes through the ign switch to 20 amp fuse to number 30 terminal
after all the safety things clutch switch, nuetral light ect computer will furnish a ground for 85
not sure about 86 been a while
87 goes to starter solenoid
best to check voltages not with ohms
must have power on #30 you can use test wire with 20 amp fuse to put power on #30
tomorrow i can pull up the touring diagram and maybe help
hth herman
to answer your question more that likely it has a bad ign switch they (reg rockets get hot and the soldier melts and the ign wire falls off.
