Confirmed for Leakey TX April 2021
Ordered the Antigravity Battery Tracker to monitor my charging system. Just measuring resting voltage don't tell much. Probably will get the battery and the Lithium Monitor and charger. I have killed two batteries with careless discharge. Once with the headlamp, once with the GPS. The Yuasa is a great battery but discharging it kills it.
Best tip since pre-loading the shifter, Exedra Max for rear tyre aaaand the Progressive 444s. Thanks.
That is the main problem with your standard batteries. If you are unfortunate to get them into a state of 'deep' discharge, the internals warp/buckle/distort and it's game over. A bsttery tender does help to eleviate and prevent this scenario, but poor memory or forgetting to turn off the lights, not so much 👍👍
Here you go Rick, i went with the HD battery, but the auto restart atx-20 is a good feature because mine the hd-20 goes into safe mode when volts reach a limit and shuts off, the atx-20 restart if you forget som battery goes to a limit, shuts down but saves enough to start the bike with the push of a button.
Pricy but getting stuck without power is going to cost. Been there and done that, twice. I understand the HD 20 comes with the re-start built in. Is that so? The ATX 20 should be OK for me. I have no stereo. Only the GPS. Probably the charger is worth it to protect the battery further. Have a NUCO that claims it is good for Lithium batteries but huuummm?
The nuco should be fine, the atx-20 has the restart, i would like to have that feature
