Jvheli
Nitrous
@warp9.9 got it right. From the factory, with the engine not in the frame they screwed it up. Also, I was supprised to see the cover is just raw casting. Its not machined at all.The bolt is off center in the gasket hole. Bet you pull her up and its pinched there. Forces a shift in the gasket. Seen this last week on a 2014. Removed cam cover cleaned gasket especially where the half moon segments front and back apllied new permates on the segments only put cover on correctly and torque. Mind you it would have been easier if the throttle bodies were off. But hey done it enough that its like wiping in the dark![]()
