atomsplitter
- Joined
- Nov 29, 2007
- Messages
- 2,982
- Location
- Keller, TX
- Ride
- 17 T-120 Black, 20 Bobber Blk, 22 Speed Triple RS
You can bench test your starter with a 12 volt battery. The clunk is the solenoid engaging the bendix drive, the starter not turning may be an issue with the brushes (if it uses them) or bushings. To test if the bushings are going out, rap the starter with a hammer (not hard enough to cave in the housing, I know it's frustrating). If the starter kicks over the engine, your starter end bushings are worn and starter needs replaced. If you set the starter on your bench and connect the battery to the end terminals it should spin right up, if not your commutation circuit (or brushes) are fried. Of course if you have the old starter on the bench you might just slip a new unit in and see what's what........
