Starmanut
Nitrous
- Joined
- Jun 12, 2017
- Messages
- 1,205
- Location
- Spanish Fork, UT
- Ride
- 2010 Rocket III Touring, Suzuki Boulevard M50
That odd bolt is T3203050, a domed flanged hex head stainless bolt M6x50mm
Sump should drop straight down with only oil falling out. While you're in there it might be a good idea to clean the 2 mesh strainers (no need for new bolts on them going back, just cleaned and medium strength threadlock)
A picture is worth a thousand words they say. These are pure gold. Thanks!!!!
I ordered the 20 M6-28's, the one M6-50, and a gasket from Engle Motors. Got free shipping from them.
I'll clean out those screens, too.
Looks like the used gasket is going to take some scraping.
1st u had mention that u had already torqued that bolt so we can assume that it was already stressed so it would have broken even if u were taking it out.
i checked mine and they were loose. so i torqued them to 80 inch pounds (we have a good tool)
9.038 Nm
i think that they would go to 10 Nm but given what u r experiencing i think i will stop at 80 inch pounds.
if u do not have an inch/Nm tool i think u should not mess with it.
The service manual said 12 Nm. But I won't do that again. Got most of them to that, though.
And from now on, I'll check them every oil change.
I'll get me a 1/4" Drive Torque Wrench from Harbor Freight. It has Inch/Lbs. I already have a 1/2 and 3/8 drive from them. The 3/8" didn't like it when I torqued the rear wheel axle and stripped a bit of the ridges inside the head. It stills measures correct, but the drive has to be in just the right place. For $12, not a killer.
I assume the parts might have to come from the UK, unless they happen to have them in stock at their place in Kansas City. Maybe I'll replace the brake fluid that I've been putting off while they are on the way.
