Brake Light Flasher
JerseyDog
2014 Rocket III Roaster (that pipe gets hot!)
I had one of these on my previous bike, a '00 Bandit 1200s, just purchased another for the Rocket. It's programmable for different flashing/delays and it does get you noticed when braking. I have mine set to flash 10 times, stay on for 5 seconds, the repeat as long as I hold the brake on. You can get one HERE
That sure is a lot of wires to be coming out of such a small device! I don't have one on my bike but I have seen them before and they do get your attention.
Supabrake111 plug and play for touring i bought, but it doesnt look good w led bulbs but stock you really notice it, this one is on you tube several settings, i think good for city drivers especially
Green is not used on this model, black is ground, blue and white are used for programming it (quick short to enter programming mode & change parameters, long short to accept current setting and move on to the next setting). You cut the hot wire going to the brake light, then the red goes on the switch side, yellow goes to the bulb.
I'm using it with an LED taillight and it works great.
