Lots of discussion here and concerns.
I’ve been using speedbleeders in all my bikes (5 so far) for 20 years. Even when I wasn’t riding I bled the brakes every two years. All my friends also order the speedbleeders based on my recommendations and I install them and show how to bleed their brakes.
For the Rocket, the ones to order are SB8125L for both front and back. You need 3 of them.
If you go this route, definitely buy the optional bleeder bag with tubing. This makes it a no mess operation, plus you can easily see when the fluid color changes showing that the lines are flushed.
In my experience, order directly from speedbleeders.com. They have a no questions asked return or warranty. I’ve gotten one bad bleeder over the years and several of the wrong size for my friends Yamaha Raider. They shipped out the replacement or the correct sized bleeders without any hassle or charge. Top rated customer service from the lady that answers the phone. Also, if you have any questions she has a good handle on the products, not just an operator.
Two things to know. Make sure to only just seat the bleeder when installing or when finished. It takes a fine touch to feel the bleeder is seated without over-torquing or damaging it. The bleeders are more fragile than the plain nipples and if you get ham-handed you will have problems.
Secondly, when you are pumping the lever or brake pedal, try not to overtravel them. I put my fingers between the the lever and the grip to keep from stressing the piston seals. Likewise, use short strokes (insert joke here) with the rear brake pedal. Have not personally had issues but have read complaints of damaging the seals in the master cylinders by being too aggressive.
There was a discussion regarding corrosion. I’ve never witnessed it but I also use the rubber caps and wipe them with silicone grease to keep them protected.
If you order directly from the speedbleeders site you should get new rubber caps with your bleeders. I think the ones from Amazon are from bulk packs and may not have the original packaging.
These are worth the money in my experience. There are several alternative ways to bleed the brakes but this method is easy, clean, and fast.
Good luck...
