https://img.jpcycles.com/zoom/ZZ24452_A.jpg
Russell Metric Speed Bleeders
Manufacturer Part Number R40527
J&P Part: ZZ24452
• Has built-in check valve allowing fastest brake bleeding without help
• 8mm x 1.25
Well I'm a bit confused, considering all of the options in this thread.
If I understand correctly, the correct thread is 8 x 1.25 as in the above link.
Then connect the bleeder bag, remove M/C cover, open bleeder and start pumping, keeping the M/C near full to avoid air in system.
ONe question, using the speed bleeder allows you to leave them open while pumping the lever? Without the speed bleeders, the SOP would be to close the bleeder valve at each release of the lever to avoid air intrusion.
Do I have this correct?
thanks
Hoopla
