Boog
Traveling Story Teller
- Joined
- Oct 17, 2013
- Messages
- 8,501
- Location
- Dumfries, Virginia
- Ride
- 2014 R3T, RAMAIR, Full Viking Dual exhaust
The new radiator is on order now. I will however attempt to do as you suggest on the original unit and then have a spare maybe.I saved my sons radiator from this fate, i used a battery drill with a reverse (LH) twist drill bit, to drill out the broken bolts. I used Krol oil as the lube. I had caused this by not using neversieze on the shroud screws when I serviced the clutch 3 years earlier. all 5 screws came loose from the heat of drilling them out, left hand bits seem to work best, never had to use an ez-out....
