Blown radiator hose
TOMCAT
Rage against the machine
ALBANY - Western Australia
2009 RIII Standard - 2008 Speed Triple -1995 900 T'Bird
Blew the radiator hose yesterday. Phone call the shop, none available in Australia ( 4 week wait on back order) OEM hose is taperd 24mm on one end 19mm at the other. Visit to local auto shop and found similar shaped 21mm hose. Made to fit a 1967-1973 Hillman Hunter, at least its British i guess :D ha ha.
So you found the leak then TC, it must have been spraying it back to the other smaller hose. I use to own a Hillman back when I was a lad, they didn't corner well as I found out.
Just fitted the Hillman hose,been for a blat down the street..not leaking;) $7 fix and more importantly bike is back on the road. We've got our Freedom Run tommorow, if weather gods are on our side should have a couple hundred bikes ( and probably just as many coppers.. ha ha) Didnt want to miss the run !!!!!!
Good old "bush mechanic" ? ;)
well done... enjoy the ride..:D
