Blown away by a sportbike in the twisties...
IFT and I routinely bury very high performance oriented, full-liter sportbikes ridden by experienced riders in our local twisties. It's all about your riding skills, the setup of your R3 (for enhanced handling/performance) and knowing that, on average, we win out in the short to moderate distance straights, they'll win out in the curves, so if you know how and when to apply your powerband, as many times as not (more in our case) the R3 will leave the squids all flustered and frustrated.
You could also reduce your front tire size from the current OEM Metz 16" to a 14", the Michelin Commander II would be my choice. that coupled with the B'stone Exedra max in the rear (which is about 1/2" taller than the stock Metz) will change the geometry, feel and handling of your R3 all for the better. The bike will feel about 200 pounds lighter, will track better, - entering in and exiting from turns quicker and easier, thus making the Beast eminently more flickable through the twisties. Better rear shocks won't hurt matters in the same respect either. Read and practice proper riding technique and learning how to take the most effective lines through any curves, plus proper braking and throttle control practices and you'll be good to go!
16 inch to a 14 inch how do you do that Phil ? Nag a couple inches off it :D
I started an 11 mile stretch of road affectionately known as the dragon with my nephew ahead of me. I tried as best I could with my limited skills to keep up. After about 3 miles there wasn't even a glimpse. When I finally arrived at the parking lot, he had removed his helmet, jacket and was working on his gloves. Physics is a *****.
weight of me+weight of bike+lean angle=slow in turns
But as stated earlier, 0-100, I WIN....
