Another series 847 copy option from another supplier. They do not ship direct to Australia but have distributors in Oz.
BENEFITS OF SERIES VOLTAGE REGULATORS SERIES regulators run much cooler than the Shunt and MOSFET voltage regulator rectifier and way much cooler than OEM parts. This series voltage regulator is an af
rmstator.com
Aussie supplier
WHY USE SERIES ENHANCED TECHNOLOGY? Runs much cooler than the Shunt and MOSFET voltage regulator rectifier. Power only flows through the electrical components when the battery is charging. Allows the stator to have lower current flowing when not used, extending its lifetime. The regulator is...
www.whitesmoto.com.au
SERIES VOLTAGE REGULATOR FOR SUZUKI V-STROM DL 1000 2014-2019 | DL 1000 X 2018-2019 | DL 1050 XT 2020-2021
$USD 139.00
Availability: In stock
SKU
RMS020-107516
Battery condition is extremely important. No voltage regulator can work correctly with a bad or weak battery.
Always fully charge your battery before performing any charging system tests or replacing parts. If there is any doubt, have the battery load tested or replaced.
ADD TO CART
INTERCHANGE PART NO
32800-31J00
SPECIFICATIONS
Dimensions:
Width: 119mm
Length: 100mm
Height: 38mm
Fixation holes center to center: 100mm
Other specifications:
Number of plugs: 2
Number of pins: 5
Minimum Charging Voltage: 14.5 V +/- 0.5 V
Maximum Charging Current: 50 A / 500 W
Open Circuit Voltage: < 15 V
Operation Temperature: -20°C to 85°C
INSTALLATION
Before installing your new SERIES Voltage Regulator Rectifier :
- Check the AC output of the stator
- Replace any burned or corroded connectors on stator and regulator rectifier
- Check and repair any melted wiring
- Use hi-temp dielectric grease on all connectors
DETAILS
The regulator is easier to mount because it is smaller than the OEM one.
ABOUT THE SERIES VOLTAGE REGULATION TECHNOLOGY
RMSTATOR’s new SERIES voltage regulator brings better reliability and charging system performance. A SERIES regulator is a significant upgrade over typical shunt type voltage regulators.
A shunt regulator controls battery voltage by grounding the stator coils to dissipate current as heat, rather than sending it on to the battery. SERIES regulators control battery voltage by intermittently disconnecting stator coils from the regulator electronics, limiting current flow through the unit and on to the battery completely.
This results in lower regulator and stator temperatures, more accurate voltage regulation, and increased reliability of your charging system components.
INSTALL LIKE A PRO
We include the opposite connector (main harness side) as we know these are often melted / corroded / defective. Defective connectors are a major cause for repetitive electrical issues.
Advantage of SH775 is that as it is slightly smaller, it may fit in the stock mount area.
I think this post is from AdventureRider but I was struck by the cool off-road Honda CX500 V twin. great little motors.
