slidderhd
Turbocharged
In a thread called "Wiring diagram for a rocket" in RDU - Rockets Downunder, rocketiiipilot showed a wiring diagram of the R3T. Based on this drawing, if I get power to the main headlight switch, I should get it to the auxiliary light switch as well, then run to the lights, then the fuses to ground. I checked all fuses and they were good. Just for kicks, I had the bike off, pulled all the fuses and checked for 12v on the fuse block. Yep, I get 12v at the #1 Fuse which shows on the diagram as the Auxiliary lights fuse. Is the diagram wrong?
