Auto tuner not working.
I want to get the LCD display but are you (R-III-R Turbo) that it wont work with the Auto Tuner, I only want it so I can perfect my AFR table map and make some alternitive verisons for those that want more power or more economy and it having a AFR and TPS% reading would help me do that
yeap AT won't run a gauge or LCD afaik, you would need the wideband O2 module (=AT module with gauge ability)
POD-300 + PC-V+ AT work great together. All engine info is ther e to see and can be datalogged to the POD.
So, a couple weeks ago I installed the PCV and the auto tuner. Everything seemed to be working fine. After riding the bike a couple days, I decided to go in and accept the trim settings from the AT unit. The only option in the software was "Delete Table".
I called DynoJet and they had me update the firmware in the PCV and set some values, so the AT would have something to change. After riding a few more miles, I checked the software this morning and nothing has changed. They walked me through everything and all the settings in the software are correct. There is power to the AT as the red light comes on when the key is on. I'm stumped on what to do now. Any ideas?
Buzz
Sorry to hear of your issues.
My bro had the same thing happen.
After MANY phone conversations Dyno Jet his unit was determined to be toast after O days working!
My suggestion is 86 the turds and get a competent Tune ECU Dyno!!!
Oh yeah - perhaps add your location under your avatar . . .
Originally posted 2012
Buzzz not seen since Feb 9, 2015
Good thread though!
