Funrocker
Standard Bore
2007 Rocket 111 'Special Edition'
Everything was OK when I bought it and it lives on a Triumph battery minder (new Motobatt battery less than 2 years ago).
It was fine but recently had a few issues with starting (starter not engaging) then it got worse and the clock sweep/dash lights started playing up. Now I get nothing except the normal headlights etc.
I've installed the ignition switch relocation kit from Just Rockets.
I've installed the starter solenoid kit from Just Rockets.
I've replaced the starter relay (right hand side by flasher relay).
I've removed the Meta alarm/immobiliser that I thought was causing the problem, and fitted a bypass plug from Abacus Alarms. It was old and I believe the battery in it was dead (made some random fizzing noises).
Fuses are all good. Battery connections are all good.
I've disconnected the battery for half an hour.
When I switch the ignition on, the lights, indicators etc work as usual but no clocks/idiot lights. The fuel pump doesn't kick in and there are no signs of life in the ignition system.
Under the left hand side panel are 3 relays, plus another one, which does click with the ignition switch. The wiring from this goes over to the right side of the bike, into the loom near the ECU. Not sure what it is.
I've attached a photo of the 12 way socket that has the alarm bypass plug in. Most of the wires appear to have been cut off and removed which makes me think the bypass plug is not doing anything (the wires don't match the few pins in the plug). I still think the alarm/immobiliser is the problem and the bypass plug may not be doing anything.
Any help appreciated, thanks!
