Alright, I just checked the TuneECU site, and it has been updated since I first tried it, and it now claims "full version" available and lists "Triumph Rocket III (all models)".
So have at it, and please report back. If I can find the tiny little adapter cable, I may give it a go as well.
Good luck.
SO far as the cable goes, if Android likes the app, the app will work with the bike and the cable won't need drivers because Android already speaks the right language.
Good luck.
Well that explains why there are two android versions.
Thanks All!! I'll let you know how it goes, might be a whole lot easier than some of the issues people have with PC's. Plus I can carry this Android easily on the bike, it's pretty cool, just starting to learn how it works, voice activated driving directions for one, of course you need to be near a wifi site, but any coffee shop or business usually has wifi,
Thanks
Hoopla
I have the 5X7 Andriod Samsung tab - Tuneecu app will work on it as you know since you have already obtained it - Use This cable from Lonelec:
Diagnostic Interface for TuneECU Motorbikes
Your tablet will recognize the Lonelec cable automatically
When the program asks you if you want to allow bluetooth, choose: NO - it does it's business thru the cable, not bluetooth - if you choose yes for bluetooth you will not be able to install tunes
Clint;
I have the Android phone, the LonTech cable and software installed from GooglePlayStore. Tune ECU loads but does not see the bike when I connect it. :thumbsdown:
Clint;
Do you have the key in the on position and the ignition switch in the run position?
Go to the Play Store on the tablet and search for TuneECU. If it comes up in the search, you should be able to use it.
Make sure to read the descriptions before buying. Sometimes apps show in the list but the description will say not compatible.
You will need the LonElec cable that comes with the mini USB otg cable. Sorry I don't have a link to it.
Also, on my Android there is a Tune ECU Lite as well as a Tune ECU -
just sayin' . . .
