Air Filter Change
Replaced with new filter from DNA. Always use their stuff on my machines. Claim ~30% increase in airflow for the rocket.
Video is up at my IG. Should be a decent overview of what it entails. Also should mention that while DNA did send me the filter for free, the content I create is of my own doing. It wasn’t part of any deal. Air Filter Install.
Many thanks.
1.Does instrument cluster lift by itself with no need to loosen any screw?
2. I guess the tank can not be lifted much due to instrument cluster still on the way? It only moves horizontally?
Correct, you might want to practice tank removal for plug change time.
Many thanks.
Cluster will pivot without the need to loosen anything. You can unbolt the tank and move it out of the way enough to change the air filter. If you want to remove the tank, it’s a bit more involved. Believe you have to remove flyscreen, then cluster, then you can lift the tank off (after disconnecting fuel and evap stuff) at least according to the service manual.
Great job buddy. That is the kind of team spirit we need to help each other. Much appreciated!!!!
