I am curious as to how much it holds down those exhaust valves
Measuring with and without would give us the answer if possible?
@TURBO200R4 is referring to the "Decompressors." Note: I've been talking with
@TURBO200R4 and
@Rocket Scientist about these things. They're not on the 2.3 bikes. Apparently, they're there to make starting the bike easier by keeping the exhaust valves open slightly.
I was getting huge clearance readings on 3 valves (as in what's destroyed in my engine?) and
@Rocket Scientist suggested it could be the decompressors, which it turns out was correct!
Important: NOT mentioned anywhere in the service manual is anything about the decompressors, other than listing them in a diagram of the camshafts. It does not give any instruction on disabling them when checking valve clearances, which it turns out that you do need to do. You simply rotate them to their neutral position.
The recommended gap for exhaust valves is .18 - .23. Without rotating the decompressors I was getting readings of .635 on those three valves! Thoughts of pulling the heads was keeping me up at night. But, with this knowledge, I just checked one after rotating the decompressor and it was now in spec. The other two should also be at, or close to, spec.
Here's a 4 second video I made that shows how they work...
Update: I've re-shimmed, as needed, all but those three valves- hopefully, they are already in spec. I got a
shim kit from HotCams.
I'm waiting on the Timing Chain Tensioner tool (T3880651) to come from Hermy's. I didn't catch that it was a special tool, as it sounds a lot like the Camshaft Drive Chain Tensioner, which is your bike's chain adjuster. This special tool is needed to apply just the right amount of tension (.6 Nm) on the chain before you tighten down the camshaft sprockets (which are adjustable on the shafts). You also need a torque wrench that hits that small number to attach to the tool. Triumph sells that for some crazy amount, or you can get one from Amazon, as I did.
Several Triumph bikes require these tools to correctly set the Camshaft Timing. The manual jumps all over the place, from section to section, making this the most confusing step, but I found a video of a guy working on a Tiger where it is explained well, here...
More later, but until then, just waiting on the tool and wishing that I could ride....
