R-III-R Turbo
Mine is the biggest :)
- Joined
- Oct 12, 2010
- Messages
- 2,386
- Location
- Ireland
- Ride
- 2472cc Supercharged Carpenter Rocket III Stroker
I have been trying to align the headlights on my garage door, but the light scatters much more than the h4 bulbs. Any ideas on making sure they are aligned properly?
i fitted an o-ring between the LED unit's 'bulb' and the H4 shape metal bezel - this moves the bulb inwards slightly in the reflector without compromising the way the bulb sits into the lamp, changing the angle the light hits the reflector at to be more acute.
i also adjusted the whole headlight units downward a little too from what it was with the stock setup. for those of us with a flyscreen/sports screen or maybe just the mounting kit for them, i swapped out the hex head bolts for some cup head Allen bolts.
this gave some extra clearance to turn the lamps downward a little (they were almost touching the old bolt heads from stock setup)
so anyhoooo here are the results in picture format; the difference is diluted somewhat due to some lights in the carpark working this time, and a pool of water, but you get the idea. much better focus of the light to in front of you, and not as high up the wall either.
If you are using a LED bulb in a reflector designed for a H4 bulb you will never get the headlamp aligned
please see above
