2020 Rocket engine guard heat.
I burnt my right calf in 2 places (mid pegs) on Friday when the outside air temp was 36degC, the rear guard was the culprit...which gasket sealant did you use, I think some have a higher temp rating than others? Going to adapt to this method once I have the right materials down.
I also keep my GT in the mid position, and the rear shield got me too.. Had to fix that, and fast.
So, what size is the hex bolt? Tried a 3mm and a 4mm. Do they actually make a 3.5mm allen key? Out of my five sets there is not one 3.5mm
Its a T25 torx bit required to remove the 3 heat shields from the header. They are threadlocked so if you have not got replacement screws from Triumph, apply some High temp threadlock when reassenbling and tighten to 5Nm.
Write your reply...
