2020 Rocket 3 TFC details released!
For the Ride
https://www.instagram.com/triumphuk/p/Bw6uEm2IbIN/?utm_source=ig_share_sheet&igshid=1pgi547pm5ypu
2019 Triumph Rocket 3 TFC | 2500cc triple-cylinder monster | MCNews.com.au
US$29,000
€33,500
Triumph Rocket 3 TFC Specifcations
NEW ROCKET 3 TFC
Engine Type Inline 3-cylinder, water-cooled, DOHC
Capacity 2458cc
Bore/Stroke 110.2 mm x 85.9 mm
Power Over 170 PS
Torque Over 221Nm
Fuel system Ride-by-Wire, fuel injected
Exhaust Stainless 3 into 1 headers with 3 exit Arrow branded silencer / CAT box
Final drive Shaft, bevel box
Clutch Hydraulic, slip-assist
Gearbox 6 speed
Frame Full aluminium frame
Instruments TFT multi-functional instrument pack with digital speedometer, trip computer, digital tachometer, gear position indicator, fuel gauge, service indicator, ambient temperature, clock and rider modes (Rain/Road/Sport/Rider-configurable) – Triumph TFT Connectivity System can be added
with accessory fitted Bluetooth module
Swingarm Single-sided, cast aluminium
Front Wheel 17 x 3.6in cast aluminium
Rear Wheel 16 x 7.5in cast aluminium
Front Tyre 150/80 R17 V
Rear Tyre 240/50 R16 V
F Suspension Showa ø47mm upside-down 1+1 cartridge front forks, compression and rebound adj., 120 mm travel
R Suspension Fully adjustable Showa piggyback reservoir RSU with remote hydraulic preload adjuster, 107 mm travel
Front Brake Dual 320 mm discs, Brembo M4.30 Stylema 4-piston radial monobloc calipers, Cornering ABS
Rear Brake Single 300 mm disc, Brembo M4.32 4-piston monobloc caliper, Cornering ABS
Seat Height 773 mm
Rake 27.9º
Trail 134.9 mm
Dry Weight TBC
Fuel Capacity 19 L
Ooh, OEM quickshifter;
NEW 2019 ROCKET TFC
With only 750 available worldwide, talk to your dealer now to own this new motorcycle legend.
Price from $29,000.00
THE ULTIMATE MOTORCYCLE
A genuine motorcycle legend, the original Triumph Rocket was a pure original equipped with the world’s largest production motorbike engine and more muscle and presence than all others. In 2019 the next chapter in this incredible story begins with an all-new Rocket, which once again tears up the rule book and sets a whole new benchmark for torque, performance, capability and style.
A British engineering masterpiece - the Rocket 3 TFC is designed to be nothing short of the ultimate motorcycle. Totally exclusive and with world-beating performance, the Rocket 3 TFC’s all-new 2500cc triple engine delivers the world’s highest torque for a production motorbike and, being a genuine TFC, spectacularly re-defines its own class with heart-stopping muscular presence, category-dominating technology, beautiful features and the highest level of premium specification equipment.
World Beating Performance
At 2500cc, the world’s biggest motorcycle production engine is central to the Rocket 3 TFC’s new class-defining performance, delivering more than 221Nm (the world’s highest torque) and more than 170PS of power, this is the most powerful Triumph to date. Adding to its unbeatable performance, the Rocket 3 TFC is also equipped with tailor-made, unique Arrow silencers with carbon fibre end-caps, for an unbelievable deep growling soundtrack.
Totally Exclusive
With a worldwide production run of only 750, the Rocket 3 TFC is a never-to-be-repeated ultra-limited edition. One of the most desirable Triumphs ever made, each is individually numbered and supplied with a premium unique TFC handover pack
HEART STOPPING Muscular Presence
The already-imposing poise and stance of the Rocket 3 TFC is enhanced by the premium carbon fibre bodywork, clean flowing lines, signature twin LED headlights, distinctive hydroformed three-header exhaust run, intricate cast aluminium wheels and incredible silhouette that together create the absolute pinnacle in motorcycle presence and style.
CATEGORY-DEFINING Specification
Over 40kg lighter than its predecessor and equipped with state-of-the-art premium branded brakes and suspension, including class-leading Brembo Stylema brakes and fully adjustable Showa monoshock with piggy-back reservoir – all designed to deliver an astounding handling and riding experience.
Following are the fast facts about this beautiful power-hungry cruiser.
1. Only 750 will be produced worldwide, with only 225 Triumph Rocket 3 TFCs arriving in Noth America.
2. Each Rocket 3 TFC will arrive with a numbered edition plaque on the instrument mount, and unique badging that features gold detailing. Each TFC will also arrive with:
  • Tailor-made TFC handover pack
  • Letter signed by Triumph’s CEO Nick Bloor
  • Personalized custom build book
  • Leather TFC-branded rucksack
  • Rocket 3 TFC indoor bike cover
3. The 2019 Triumph Rocket 3 TFC will be powered by an all-new 2500cc triple that produces more than 163 ft/lbs of torque, which the Hinckley-based brand says is 70 percent more torque than its nearest competitors. The engine produces 168 horsepower, more than 13 percent higher than the previous generation. This makes the TFC the most powerful Triumph to date.
4.Triumph didn’t go crazy into details, but says that the Rocket 3 TFC engine features “state-of-the-art” components such as lightweight titanium inlet valves, which allow for even higher revving than the previous Rocket, and tailor-made features including the unique Arrow silencers with beautiful carbon fiber end-caps.
5. The 2019 Triumph Rocket 3 TFC is 15-percent lighter than its predecessor for a weight savings of 88 pounds (dry weight of the Rocket Roadster is 734 pounds). The following contribute to the weight savings:
  • All-new aluminum frame which uses the engine as a stressed member for mass optimization
  • All-new aluminum single-sided swinging arm
  • Engine component refinements
  • Carbon fiber bodywork
  • Lightweight braking components
6. In regards to suspension and brakes, the Triumph Rocket TSA uses Brembo Stylema calipers, an adjustable 47mm Showa fork and a fully adjustable Showa monoshock with a piggy-back reservoir. The premium specification continues with a Brembo radial master cylinder and MCS span, ratio-adjustable brake lever, and matching clutch lever.
7. The 2019 Triumph Rocket TFC arrives with the following electronic and rider aides:
  • Cornering ABS
  • Traction Control
  • Four riding modes (Road, Rain, Sport and Rider-Configurable)
  • Triumph Shift Assist for clutch-less up and down shifts
  • Hill Hold Control to prevent the bike from rolling backwards when stopped on an incline
8. The Rocket 3 TFCs rolls on twenty-spoke cast aluminum wheels with a 240mm rear tire.
9. The Rocket 3 TFC was designed for bold appeal, and features a premium twin carbon black and matte carbon black paint scheme with brushed foil decals, gold accents, electroformed 3D Triumph badge and hidden pillion footrests contributing to a clean, minimal rear end.
10. Besides the signature twin LED headlights with Daytime Running Lights (DRL), other aesthetic highlights include the following carbon-fiber parts: front mud-guard, silencer end caps, exhaust heat shields, fly screen, drive shaft cover, heel guards and tank strap all add to an unmatched level of finish, compact LED indicators, taillight and number plate light.
11. The Triumph Rocket 3 TFC features full-color, second-generation TFT instruments that are more sophisticated than the previous generation. The minimal stylish design of the TFT system offers two information layout themes and a feature that allows the rider to personalize their start-up screen.
12. Cruise control is standard, as is keyless ignition, Tire Pressure Monitoring System (TPMS), and a USB charging socket.
13. In addition to its standard specification, an accessory Bluetooth connectivity module enables the Rocket 3 Triumph Factory Custom’s advanced TFT instruments with full connectivity to the world’s first motorcycle-integrated “GoPro” control system, Triumph’s “turn-by-turn” navigation system powered by Google, as well as music and phone operation.
14. Triumph is taking orders now for the 2019 Rocket 3 TFC. The bike will be available in December for a price of $29,000 (MSRP).
If I were the same age I was when the 1st Rocket III came out, Id be all over this thing. As I've mellowed I've learned to be patient. The electronic advancements, styling, and the visual appeal of this beast has had an earnest desire to talk to my dealer on a deal for us to go halves on a numbered bike. They park it in the show room I come and ride it around and hand out cards. Mr. Bloor needs to recoup R&D for which I don't blame him but I can't make the mark myself. My Longenes Conquest Classic ain't a true luxury but it sure set me back a few. And time tells all. Speed used as a tool, improves time. As all Rocket Captains can attest.
I went back and looked at the video -- the left side was available in the "runway" run outside, and was almost completely in the dark, except for some flashes. I suppose, with the right software, one could make a frame-by-frame view, and stop on the frames where the flashes went off - I don't have that patience. I presume we'll all know soon enough.
I notice on this forum there is considerable upgrades at considerable cost happening. Looking at this beast made for a talented rider obviously I don’t see a lot of upgrades needed, being a grasshopper only I ask the question is the bike really overpriced? Lot of top notch gear on that thang. This bike is kinda like the usmc only the few and the brave are gonna have this bike. 750 (young) men with big kahoonas
Agreed. Been on the fence and luke warm over the motor, BUT reading what its got . . . stiffy!
I like the left side well enough, the rear has me puzzled still, have to see one, yea right
Hoopla
From what I've seen the tank is the same on both sides and the intake is lower
Thant is what I was thinking. Than would give it a more traditional Triumph tank profile. To bad they reduced the fuel capacity.
Thanks for the new pics guys. I do like they way they handled the intake on the left.
It is a nice looking bike, and all of the electronic goodies, definitely make me want one, but WOW, after freight, pdi, and the multiple different taxes we have to pay, this thing is coming in at almost $40,000 Canadian, i'm thinking a used Roadster with Carpenter kit, and we are all good.
Write your reply...
