Neville Lush
www.nevillelushracing.com
- Joined
- Feb 26, 2007
- Messages
- 1,038
- Location
- Victor Harbor South Australia
- Ride
- Speed Triple 1050 Dirt Track sidecar,H2750Roadrace sidecar W800 Kawasaki
Random comments...
I reckon you would need shorter rods if the stroke is increased. It may be possible to raise the gudgeon pin in the piston a bit. Crank IS ONE piece. You MAY be able to get say 6mm stroke increase if one could find a rod with a smaller big end eye and offset grind the crank 3mm. The crank would need to be hardened/nitrided before the final few thousandths are ground off. To bore out a R3 engine one would have to bore the lower part of the block so a thicker sleeve could be fitted and then make a larger diameter rebate in the top of the block surface. All of these things are possible with the addition of $$$. I have yet to find a person who would wish to pay for this.I have confirmation that we can get longer rods from Carrillo rods.
