I have a 2014 R3R with 12497 miles on her On the 7th of Dec, while shifting from 4rh into 5th at 65 mph on a busy interstate, my transmission locked up causing the rear wheel to slide I immediately pulled the clutch in and the tire released nut locked if I attempted to release the clutch. There was a loud clunk just before the problem. The transmission is locked in 1st, 4th, and 5th I can get the bike to move in 2nd and 3rd but sounds like metal on metal grinding. It acts as if there is something in my wheel, it attempts to move but is binding.
Has anyone else experienced this type of failure? It is not the detent spring as i have removed the front cover. Next it to pull the engine and check the gears.
