Mongler07
Turbocharged
Like I said there are 2 already there. Maybe I should have said to use the ones that you take off. And I should add that you can use them over and over if you temper or (aneal) them.You would still need a compression washer on each side of the spacer to not have a leak. Goodway to check for by-pass inside M.C.. Good tip R-III-R Turbo
