chrisw
Bluebird
Well the shock as the site say plus 10 over so all the way in should be stock and 10 mm adjustment to make them longer
Unless I'm not reading it right. Anyway I'm running a 18 inch 240 battle criuse h50 rear with 5 mm rise so its like having the 240/55/16 my front suspension is Ducati internals with high speed dampening and compression rebound adjustment and length.![]()
I carry a wrench with me but running the 140 battle cruise h50 front my fork length is typically 1/2" or so shorter then stock length for highway cruising and with a quick setting change on the the steering damper she is smooth as sill above 160.![]()
So in the twisties if I'm going to ride briskly I'm running usually about settong 4 on the damper and take about 2.5 to 3 turns out of the compression lowering the front end a wee bit more. If I start hearing the feelers screen to much I'll put a little more height in the in her ehen I get back at the trailer . Until then I'll just hang off a little more so she can stand up a little. There's times I kind of climb all around on her in the twisties
22,000 dollars for a new rocket and ya don't get a suspension like mine![]()
Awesome set up u have. Can I ask which model of Ducati did u use ? I never thought of using internals from other bike.
I like the idea of being able to vary the front end for different rides. I too, like to hang off if I see an opportunity (long fast bends). I added pegs to allow easier body movement.
Lots of options
