dobro
It appears to me that there are 2 different ways from which one can choose to accomplish "reset adaptives" after installing a new map. The first way does not require using the Tuneecu program or a computer at all--just start the engine w/o moving the throttle and after it reaches 90 degrees let it idle for 12 minutes then you are done. The second way requires connecting the Tuneecu program, selecting "reset adaptives" then starting the engine w/o moving the throttle and letting it idle until the TPS bar turns green then selecting "disconnect" and turning the engine off.
Other than seeing the TPS bar turn green to indicate the reset is complete, is there any reason to choose the second way over the first way?
