Does this mean my R3R is tuned ?
R3Rblkshdw
Hey guys I've only had my rocket for about 10 months and just started reading and getting into tune ECU and the maps. Today for the first time I plugged it all up and got the bikes installed map info and saysap 20773 which on the tuneecu list shows it's a tuned map.
Can some one helpe find out if it really is tuned or not? I'm attaching pics of the info from tune ECU
Thanks in advance
just by looking at the map info it will not tell you anything tune wise. on the newer bikes it shows the amount of reflashes which is an indicator but still means nothing tune wise.
if the published list shows it as tuned, there must be some references to the changes I would assume.
compare the 2 maps and see if there are differences and what they are.
I unfortunately I don't know the roadsters
Thanks in advance
This is a Triumph Custom tune by Ulf Penner.
It will give you smooth running..full power...secondaries open to 100% in all gears and the speed limit is cancelled...so yes it looks like you have yourself a good tune.
If you go into 'TuneEcu Custom Tunes" and scroll down to your bike and the 20773 map you will see it there detailing what i have quoted.
So the good and the bad of this is... Awesome in that you have a nice tune and if you are happy with the performance, you are set. If you were looking for more, then it is definitely going to cost you. The tune is the absolute best bang for the buck out there for increase performance of the Rocket.
Hey guys I appreciate y'all's help. I went in and read the map info and it confirmed what's on the custom tune list. Well I feel much better now knowing it's already got one of the best tunes out there. I checked secondaries and all showed at 100. So I guess now I'm done with the tuning.
