What is the best throttle lock to buy
I noticed on their website that the BrakeAway isn't compatible with heated grips. Has anyone with heated grips installed them on their rides? What was the issue?
Not sure as I don't have heated grips, but likely the way the electric wire comes out of the molded rubber? It would interfere with the mechanism.
I believe the wire comes out radially, maybe someone could put up a picture?
I just installed the Atlas Throttle lock. Im loving it.
Took 5 min to install. Fits with smallest friction pad I'm loving it so far.
Heh heh heh MACCRO lens.
Very interesting and thanks for the link!
BTW - A nice advantage/disadvantage breakdown of different types on the atlas site
Throttle Lock Comparison Chart
One thing I like with this is that on/off button rotates with your hand. I use a palm rest on both my bikes so my hand position is fixed.
Also looks rather "rustic" which appeals to my mindset.
Hardly an unbiased comparison made by Atlas!?!? :rolleyes: :roll: :thumbsdown:
My "mounts to grip" Go Cruise 2 is the simplest, easy to use that I have seen.
Most of the negatives suggested by Atlas are untrue. Tis very easy to set (a slight push downward to the brake lever by your index finger).
Tis NOT a dangerous lock, but temporarily restrains the throttle while you scratch or stretch. Always able easily to roll back throttle if needed.
Out on long stretches of freeways, I set mine to just cancel out the spring pressure give a little relief to my right wrist.
