Well, I lost the gas cap...
Any standard HD gas cap should screw in just fine
I think so too. Some of the caps I found said they worked on 1983 and up Harley sportsters as well as the triumphs. That would definitely open up some options. I am really intrigued to make a kit to make the monza lid a real sealed cap to remove and replace the factory one.
Thumbs up on that! Also wondering just how unique our screw in cap is. If you only had one and could go to the right NAPA store with a helpful clerk I wonder if you couldn't get a close enough match.
I know there's a cap hiding on their shelves that would work. My only concern was digging for one without the giant raised finger bar across the middle, for lid clearance concerns. Also i grabbed the cap off my truck and it grabbed the threads, but it was too large in diameter and caught the lid base ring.
If anyone could shoot a picture of the bottom of their cap that would be most helpful. I'm really just looking for what the original sealing surface and o-ring gasket look like. Thanks!
6 mm thread-to-thread (red), 25mm from bottom of seal to bottom of threaded section (orange), 4 mm from bottom of cap to bottom of seal (green), approx. 44mm O.D. for threaded section (blue).
So much detail! I can even see it has a double lip split oring seal. You're awesome for this Einar, thanks!
Well I finally made the monza lid into a real cap! I will post a new thread for it but here are some pics.
20250620_201449.jpg 20250620_202459.jpg 20250620_204149.jpg 20250620_204156.jpg 20250620_204243.jpg
Does that provide the same tight seal?
Not yet. It seals fine for riding without splashing out, and I filled my tank to the very top where the gas was over the metal baffle when I test rode. The bolt hole in the middle is what I have to address. I need to fabricate a custom slip bolt based off the original design that screws into the threaded hole of our monza lid. Then it will be a truly sealed vented cap. I will continue to ride it like this until i can make that part.
