when working on something that someone else has work on u need to consider the fact that u have the original problem plus the problems he created while working on it. (maybe several things wrong.)
u might start by pulling the three oil drain plugs. this should drain the storage tank. check for debris in the oil. cut around the filter near base then open it up to see what is in it (if u cut it with hacksaw it will have the material the comes with sawing. )
the more info u can give us the more info we can give u.
wjb post looks like a good starting place.
there is an anti drain valve that may be in backwards?
i guess my opinion would be go in the front and check out what wjb said and see if thee chain is turning the pump ect.
It is possible to fit the non return valve in upside down when you are refitting the bottom sump plate. I do not know if it would stop the oil flow to the pump though.
Thought you had it off already - if you remove the front engine cover next, pop a plug out per cylinder, turn it over clockwise by hand via the 'nut' (clamping piece is what Triumph part name) on the crank nose, with a bit of oil in the tank, the spray bar (on the pressure pump) which squirts oil at the clutch should squirt some.. if not, you'll know that pump ain't getting/pumping oil.
After you have done all the checks and you have not found the problem .
I would remove the front of the engine ,remove the clutch basket to get to the oil pump.
Remove the 3 bolts on the pump and split the pump,remove and clean the oil pump filter screen from inside the pump, Wet the pump well with oil and put it back together, spin the pump CCW with a drill to check for oil flow at the oil sensor tapping point..
Side cover is off - see pic
I will be removing the clutch basket next... Note: a small piece of Metal which to me was part of the locking washer (not sure was sitting on the bottom of the casing below the basket. See pic.
You definitely have NO oil pressure. That whole exposed area should be dripping wet with oil, even after it's sat awhile. That looks bone dry. Don't try to run it anymore. It maybe too late.
We will see - the pics tell a troubling story - so I will need to order a new gasket for the front side, filter gasket, and what else after I took off the clutch basket something needed to be replaced at that time also.. what else do we need to look at while we have this apart.of gasket use - see attached picture:
I am on phone and do not reconize what is plugging the filter. Do u know what it is and where it came from?
U need to open pump and check for scratches and heat damage from lack of oil.
