TurboFan
Truth in advertising. There are little flaws all over the bike. One of the stand offs on the header came loose and I stuck it back on, which burned off the powdercoat. There is another that needs to be tack welded, also visible in the same photo. There are stickers from El Mirage which record the runs the bike made. Leave them on, they will probably be hell to clean off. Also the LSR badge on the rear fender will be hard to get off as will be the frame number sticker (all SCTA stuff) The two white specs on the rear of the saddle bag is white paint, I know, I know. Look carefully at the seat back for the passenger. There is a small tear in the naugahyde (thank God for spell check). The chrome on the front part of the fender cover won't polish any more and the Left mirror acquired some scratches (actually splitting lanes right near my house and I wacked a mirror which thankfully folded in and didn't seem to be damaged. I really couldn't tell, it was way behind me by the time I got the mirror straight)
The third picture doesn't show it well, but the middle of the top of the tank has a patch of clear coat that is textured like a towel. The clear coat was still soft when I installed the tank, filled it with gas and it began leaking from a bad fuel pump gasket. I pulled the tank off, and set it upside down on a towel which printed into the soft clear coat. Might polish out? Probably needs another coat or two of House of Kolor, Show Clear, and then buff it out.
