Vibration, Cause for Concern?
New owner of used R3R and I'm getting used to the bike.
I have felt a vibration, almost like clutch judder on take off and quite vibey sitting on 3000 rpm just cruising.
I did a little testing on the way home today. Clutch in, on a downhill run and the vibration goes away. Clutch in and hold the revs at 3000, still no vibration, leading me to conclude that it's in the drive train.
Have you tried anything like this on your bike to isolate the issue?
Cheers.
the some of early rockets had the same 3000 rpm vibes including me.
if you were just riding and you just touched the clutch lever it would go away.
so it does not suprize me that it goes away
try bring it up to 3000 in nuetral then take slack out of clutch lever and see if it makes a difference?
for some of you i know what you are thinking. do not tighten up the clutch to take the free play out. it screws up the clutch system.
hth
