we dont know yet if new rockets storms have 2 or 1, but if its 1 then good, but no one has confirmed that yet if there are 2 o2 sensors in new rockets, if someone has new storm they can just find both of them by inspecting the headers cat exhaust visually and confirm
my best guess would be is to have a good mechanic to read the rear sensor (guessing about .5 volts) then maybe if furnished that amount then the ecu might be ok and not set codes.
that is if the tune ecu will uncheck the number one o2 sensor.
Not sure if anyone here can verify, but when I called my dealership they said to pop the seat and if the plug cord was large and black it’s the Euro 4 version with one O2 sensor and it’s the Euro 5 with two sensors if the plug cord is small and red.
when you are taking 5 minutes out of your day to post something we are not very concerned about caps.
most of the guys replying knows alot about this but you have to have a 2025 to experiment with like
1st copy map so that if something goes wrong you can reinstall it. try to put a check mark in the box o2 number and see what happens.
i would not attempt a download till i found out if you can change the two o2 sensors plus i would not buy the exhaust till you learn what is going on.
Unchecking the O2 box doesn’t disable the sensors. It suppresses throwing an error code. So, if you uncheck the box and reload the tune and unplug both sensors and you still get a check engine light, you’ll know the Tuneecu check box doesn’t work for both sensors. Then plug in both sensors and clear the code with Tuneecu.
I just did a visual inspection on my 25 and can only see 1 O2 sensor, also called Triumph with my VIN and was told only 1 O2 sensor.
It's possible though I wasn't able to see an additional sensor or their information is inaccurate.
