That should be onterst
DNK Tuneworks has some Rocket experience now. I have them writing a map for my bike with the bugbike pipes right now. Bike will be at the dealer next week for the brake recall and first service, I'll probably flash it as soon as I get home and log.
That should be interesting.
I downloaded maps to android phone, when I try to open, I get message says I have no apps to view file. file is 31024map.hex
Open it in the TuneECU program under the maps tab. If you haven’t moved the file, it will be in the downloads folder.
I can't seem to find map tab, this is only other screen I see besides main.
Did you purchase the program on Google play store? There are 5 screens. From Sensors, swipe towards the right to get Adjustments, then Dashboard, and then Map. Swiping right from Map gets you to an F Trim table. On the Map screen, in the upper right, there are 3 tabs, Map (open a map, etc), Table (to modify the map), and ECU (to connect, select your ecu, and download a map). Good idea to find the manual on the TuneECU Facebook page or here:
Thank you very much sir, finally got it to swipe, must be my ****ty little phone, Time for a tablet, are there any that work better than others for Tuneecu?
I used an Acer Iconia one but Samsung tablets also seem to work. These require an OTG adapter. The tablet you choose must support OTG. The manual I linked to has recommendations. Also there is a new version of TuneECU - make sure you get it.
I'm in the minority here. I love the look of the pipes and the way the engine is at the moment. You can feel she has a lot more in her but whether I want to tap that and play with something that comes out of the factory so nicely prepared IMHO vs many other bikes that don't, not sure I want to head down that path just yet. Already did the clutch so a little wary ATM. :)
Curious as to why so many people want to play with the tune? Serious question.
