TuneECU .... free tuning software
Hi Doug, running TORS exhausts with cat by pass. Inlet as standard, looking at map 20219 with secondariness set open. Not certain at the moment about uploading map to ECU as I still have 10 months warranty left & don't want to void it, but may have a go so long as I can save the current map & revert back to it if need be. Probably overcautious but that's me.
I have the same setup and have run various tunes with Tuneboy. Right now, I'm running the standard version (20226) of 20219 but with the secondaries open 100%. This is working fine for me, especially in cold weather when it tends to run richer anyway.
I would make a copy of 20219 with the secondaries 100% open and the speedo fixed. No one will ever know what you've got in there. Assuming that the TuneECU version of this tune is OK, you shouldn't have a problem and you can always reload the standard 20219 before you bring it to the dealer if you're concerned. Opening the secondaries will give you about 10-12 extra ft lb of peak torque (2700-3000 rpm). It's a pretty minor change.
Update
12-15-10 TuneECUv1.8 now released
Support Speed Triple 2011.
Copy / paste the table values (individuals and groups).
Adding a DLL file and delete key.
BR, Tom
INFO
version 1.8.1 available soon...
- KTM : Added tests features
- Sagem : Devices (O2 sonde, SAI) disabled in version 1.8, bug fixed.
BR, Tom
Update
12-19-10 TuneECUv1.8.1 now released
BR, Tom
Hi,
For questions about programming TuneECU, please contact directly Alain, he is the programmer.
The contact address you can find on our homepage. There select the support address.
BR, Tom
Hay Tom any chance you can add the indervidual MAP sensor reading under sensors ?
