Tune ECU question
Mark Koskey
Standard Bore
Omaha, Nebraska
Just wondering why the touring ECU will not accept all the tunes I see on here?
Cant you just copy/paste the F and I tables if there is a tune that closely matches what you have into the tables?
Worked on many tuning softwares for awhile and before I dive into my stock 13 just wanted to make sure I wasnt doing something bad!!
Thanks
The earlier bikes used a different ECU base.
Yes I am aware of that. The question I wanted to know was if I could copy/paste the trims for the fuel and ignition into either/or maps. Or is that what you meant by base? Say in F1 at TP 15% and 7000RPM it says 4205 in that cell. If that is stock setting on a 2013 rocket touring that cell has different number if I look at a map from say a R3R?
Sorry just want clarification.
There is a REALLY good tune for the R3T done by PowerTripp a couple of years back and made available to us. If you ask @HansO nicely then he will probably send it to you.
There is a Tripp tune for Touring on the TuneECU web site:
You can't load a Roadster tune into the Touring but the tables conform. I don't know if anyone has done this or whether it will mess up the ECU but, I opened the stock touring tune (20367) and then loaded the Roadster tune for TORs (20776) with the compare function. I toggled back and forth with the F6 key and copied every table in 20776 into the touring tune.
No need to ask Hanso, you can just go here:
R3T derestricting
That gets you up to about 140 hp, so you're pretty much at parity with a stock Roadster. To get more than that you need to replace your air filter and do something to the exhaust (finding full systems for the Touring is a bit of a challenge...) and then put the bike on a dyno.
But the above tune is a revelation for the Touring. It doesn't really rev willingly past 4k at all stock - put this thing in there and it pulls like a freight train up past 5500 as it should.
The R3T deristricting is excellent, turns it into a completely different bike. Not a roadster, but pretty **** good for a bagger.
I already have the TORS and ramair(Just need to install the ramair), plan on getting the Viking header and cat box delete ordered here shortly. That is why I was asking the questions about the tunes. Im a HP junkie!
The trips tune will be to lean with the ram air, and if you do a header replacement you will need a dyno. Maybe talk to @HansO to see if he has something to accommodate you.
