TTS cnc milled chargerbracket
unforgiven
netherlands(europe)
Hi, did anyone had some problems with the TTS chargerbracket/cover ? What about the crankpulley bearingconstruction behind the crankpulley? Did TTS fixed any modification about that item with its bracket?
If someone knows, please let me know. Tnx !
TTS has been updating the crank drive and bearing area over the years. I have seen a couple variations. I believe he no longer uses the pin bearing type and complete drive with gear. he now uses the OEM crank gear with a drive hub that goes on the end of the crank and a roller bearing. in fact my newest style used a roller bearing (Ball type) and I think since this style he has gone with a larger roller (Ball type)bearing. These are on the newest design which changes to hydraulic clutch actuator and the ability to open the clutch without pulling the cover. I have not heard of any problems with the newer style.
Let me guess your needle bearing ate up the end of the pulley drive shaft and she is leaking oil?
Your guessing is right! And tnx for your info !
I would give him a wring and see if his newer drive style is adaptable to you cover. If not you might need to update your cover.
ok. I shall contact TTS and ask them about the adaptability of the newer drive style into the standard cover. I don't think so but still asking them doesn't cost much, till then.
