Trip and clock reset
Phil Barnett
Mission Hills Ca.
2008 Triumph Rocket III Touring
Not sure if this is the folder to ask this but here goes.
When I shut the bike off, the trip counter and the clock reset back to zero. I just got the bike with 28 thousand on it so I'm not sure of all the little details yet. I find this a bit odd that it does that. Also, how accurate is the fuel gauge on these. I rode 120 miles today and it was showing just under half a tank on the gauge. All help is appreciated.
Phil
Have you been having battery problems? Sounds to me like shes about to leave you stranded somewhere with a dead battery
Phil
Having only had the bike for two weeks I would say no. No problems starting after sitting for a week.
The fuel gauge on our bikes is a topic of many discussions. I like having it and say mine is pretty close to accurate. But many are somewhat off. When I ride the highways, I can get 195 to 200 miles with half a gallon left. The gauage will drop to empty at times around 180 though. In town riding I get 150 to 160 miles with half a gallon left; the gauge will show empty around 135-145. Bottom line is experiment with your particular bike and keep a few notes on what the gauge show you verses what you put in when you fill up.
Try tàking the assembly off and disconnected wiringit just unplugs and check for corrosion.Put some di-electric grease on the contacts and reassemble hopefully this will fix the problem.
Thanks. As long as I can get somewhere in the neighborhood of 150 to 175 miles on a tank I should be good to go. As soon as I get my trip meter issues worked out, I will be able to gauge this thing better.
