HansO
Not Taking Life Too Seriously
- Joined
- Apr 4, 2010
- Messages
- 13,447
- Location
- Batemans Bay, NSW, Aus
- Ride
- 08 Rocket III R.I.P now TEX Triumph Explorer
Toyo is the only DS that I have heard of rubbing the sidewall and like Hellfire said it HAD TO BE the psi.
The only negative that I can think of is at walking speed.
Every time you hear of some one (including me) running on the sidewall it is always the Toyo and it is pressure related the Toyo Proxes T1R which have a 280 wear rating (one of the softest tyres available) has to be inflated at least 3-4 psi more than other DS tyres due to thier softer sidewalls and I found the balance was to not go quite so high to maintain the ride quality I have done 15,000 klm's and while I occasionly see a slight marking there is no actual wear on the side wall in fact you can still read the fine print on the sidewall ifyou look carefully you can still see the writing is still intact
