Want to Buy TORS for 2014 Roadster
If they will fit my '16 roadster I'm in line....
I believe they will #A9600322: Triumph. Silencer, RH shows part A9600321 and A9600322 fit Roadsters from
I'm not arguing, just trying to weigh the options - If you band or tape the boxes together (really well!) it may end up being cheaper - $250 saved is $250 earned - sounds like a plan - PM me with a paypal email and get it out to you
The LH ones are about 32 inches long, and 6 inches across. The RH one is about 30 inches long and 6 inches across. They all weigh around 12-15 lbs each.
It would likely cost about somewhere between $25.00 to $35.00 each, but I will look for the best option.
Let me send you pics tonight so you can be sure what you are getting - I don't want anyone to be unhappy.
OK - I'll be here. Sounds like I may have to move my saddlebags a bit, they appear to be a larger diameter than stock? Just checked my stock - 6" is right, just put a tape measure down so I can see where you are measuring the length from
Thanks
They appear to be exactly the same size as stock on my 2010. The crossover box remains and they just bolt on where the stock ones come off.
I also have the Triumph OEM saddlebags and am banking on them not being any bigger. I had them laying next to the bike a few weeks ago in the garage and pretty sure they are the same dimensions.
I used the original sellers dimensions in the chat, and will re-measure them again tonight.
I added a link to my google drive where I took more pictures. The one box is 30 inches long and the other is closer to 34 inches:
TOR - Google Drive
Thanks for going the extra mile - these should bolt right on as long as the bracket holes line up - send me youorPayPal info and I'll get the payment out -
