Thoughts about this?? (Radiator issue)
When I was trying to get mine fixed most shops didn't want to touch it because it was aluminum and they either didn't have the tools, the equipment or the knowledge to weld aluminum. That is why I sent it to Myle'rs to get it fixed.
bob
Be aware, I've known some radiator shops that claim to repair aluminum radiators, but only use JB weld.
I will take a look. Just hate to be without the wheels for that long. Thank you...
Take it back to "The qualified tech" and demand they fix the F*cking thing properly.
Well, now I'm not sure sure about the "qualifications?" They did pressure test it the first time they repaired. As my cap was the original from 6 years ago, I changed it and then the leak started to show. Maybe not used to having the pressure again? not sure
If you can find the leaking spot, your local welding shop should stock aluminum brazing rods. You could should be able to do this in your garage with a MAP gas torch. The only problem might be that the leak is on the side of a tube and not accessible.
