So what did your meter say about your stator?
Sorry, I was out today. It tested .6 ohms between all three pins. It was also not shorting out. I tested the voltage on the battery while it was running and brought it up to around 5,000 rpms. It did not get above 14.5 V. I could feel the middle relay fuse on the left side of the bike kick on when I turned the key, but could not feel it kick off within a minute after shutting off the bike. Maybe that is the problem?
Yes, you should feel it in about .45 seconds that means its gonna drain the battery 14.5 is good
Write your reply...
