britman
Nitrous
- Joined
- Sep 8, 2006
- Messages
- 1,400
- Location
- Fredericksburg, Virginia
- Ride
- 2005 Rocket 3/2014 Moto Guzzi Touring
My solder repair on my ignition switch has apparently gone south. Lately when you turn the key there is a dead spot and you have to wiggle the key to get full connection. Since I installed the Gipro and the Odyssey battery it has gotten worst, probably from the testing and extra juice. I called Baxter Cycle today thinking if anyone would have a unit on the shelve, it would be them. Unfortunately they didn't but they did tell me there is a Triumph bulletin out to the dealers on the ignition switch connector. Apparently there is an upgrade for the dealer to install a more waterproof connector in the harness for certain models. I called D&D Cycles in Norfolk to order the switch at a cost of $172.00 and they are sending the new connector along also. I will have to have two keys now because I am way to cheap to order the whole lock, tank, and seat set. At least the problem arose in my garage and not on the side of the road.
