Supercharged bike blowing oil cap off
My bike froze in my garage (I assume) and it pushed about a half guart of oil out of the engine. I haven't gotten into it yet because I have a car engine torn down, but does this sound like maybe water leaked into the bike's oil and froze? Again, it happened after a sub zero night in this rented house with an unheated, non insulated garage.
what part of arizona.
pics of oil leak?
sometimes antifreeze feels like oil.
need more info.
pics of oil leak?
need more info.
I am in northern Arizona on the White Mountain range... We had a freeze in Taylor, Az. A couple days ago, I removed the front drain and oil filter and drained the remaining oil which turned out to be about 4 quarts. The oil reservoir was already empty and I assumed the typical o-ring leaks was the problem, but just today, I walked out to the bike after buying new synthetic oil and (Costa COF6607) filter only to see another puddle under the bike. probably the last bit of oil. I have not yet cleared around the bike again to lay down and look underneath the engine/transmission, but this is gnawing at me quite a bit. I looked at the oil which drained out for signs of coolant, and it appeared to be overly dirty even though it was changed less than 1500 miles ago.
i am not familiar with that filter
Purolator change their filters so that it gets tight before the rubber seals and then it leaks
just info
If it sat there without a filter on it should have a oil puddle as it would have drained down the main bearing ladder and and some inside oil passages. Of course blowing the oil cap off from the boost probably spit out out to. Atleast the three times the deterats chewed on my pistons :(
