Suggestions for luggage with stock rack.
That's what I'm talking about. I found that one or a similar one and, in any case, that's definitely and option for me. I'll have to check that out a little more but the one I found online the other day was a bit small. Reviewers on Amazon said it would only hold the equivalent of a pair of shoes. But there are larger ones and the one you link may be larger. I really like some of the other bags I found too. It's almost overwhelming how may there are to choose from but those are the sort of things I'm looking for. Thanks for the link!
Its plenty big enough for me, I can fit quite a lot in the main bag which has an access flap as well as access via the sides, it is also expandable a small amount either side and has two side pockets. You'll fit a lot more than a pair of shoes in it. Good luck!!! I paid $139AUD for mine.
Forgot to mention it also come with a waterproof cover and sits on the rack real nice.
Thanks for the info. I'm going to check it out. By any chance, do you have a picture of it mounted on your bike? If so, it would be helpful to see it. One problem I found while looking at various luggage options is that the most of the pictures don't show it on a bike for reference so it's hard to tell just how big they are other than the volume rating. I found some that looked promising but managed to find a picture of them mounted on bikes and only then realized that they were too big or two small.
I bought a new Rocket III touring a couple weeks ago and I'm in the market right now for some kind of box or bag that will attach to the stock rack that the bike came with. I know it's small and it's not rated for much weight (although I've read that the rating is overly conservative) but, for now, I'd like to get a box or, preferably, a bag or semi-hard bag. The reason I'm asking for recommendations is that, while looking at various options, it became overwhelming because there are so many.
For now, I just want something that gives me a little more storage. Later on, I would like to get something larger. When I do that, I would really like it if there is a rack that I can change out to without modification so I can pop the original rack/backrest back on when I don't need the luggage. Is there anything like that available? Unfortunately, in my searches, that information isn't to be found.
Our first trips (with my wife) will probably be trips around, say, Lake Michigan or Lake Superior (I live about 35 miles west of Chicago. Later on, I'll probably add a passenger seat bag when I do longer solo trips. (Back in the 60s, I wandered the country for 18 months, never staying in one place for more than one day with one short exception. I did that, believe it or not, with a Triumph Bonneville and only a sissy bar that I strapped everything to. (See attached picture.)
To summarize: I want a small box or (preferably) a bag that attaches to the existing rack without modification. Later on, I'll want a rack that replaces the existing rack without modification, if possible, that I can attach rack and passenger seat bags too. I'll probably be doing solo trips to see my son in Oregon, etc., with that setup.
Anyway, with those requirements in mind, I'd like to hear what other folks here use, like, and recommend.
(EDIT) I'm adding this as I forgot to mention it when I first posted this. I want a luggage system that can easily and quickly be switched out to put the bike back in original configuration. I don't want a box on the bike unless I'm on a trip. I don't want to do modifications or changes to the rack, etc., that would be a PITA to switch back and forth. Ideally, I would like something that only requires removing the factory backrest to install and can be attached to the factory rack, even better, has a built-in backrest for my wife. I've seen soft and semi-soft bags that might work.
I asked the same thing a few years back and this guy did a real good job with his, you can buy a mounting bracket that will fit the Triumph rack.
I use a SAC cool SAC combo for trips. The two bags easily hold enough for the wife and I for a week to 2 week trip. The main bag clips to the luggage rack and has a wide strap that goes over the backrest and pad. The smaller bag clips to the top of the main bag or can be used in place of the main bag. The 2 sizes gives lots of options for weekends or longer trips.
Boy, people really don't read much of the original post before chiming in, do they? :)
I guess you couldn't figure this one out on your own so here's what you do, buy a second rack with the quick release minus the cissy bar and permanently mount the box onto it? that way you keep the original as is and just switch them out as needed.
It's not rocket science but I did feel the need to break it down and explain it for you.
Hope it helped.
If you need anymore help like for instance how to turn your Ignition on feel free to ask I'm only here to please.
Since you've got the bar and rack, get either
the first suggestion (grand tour) or I got the saddlemen version. Easily slides over bar for on and off, couple bungee straps and done. As to weight...I've traveled over 30k with saddlemen set up, it's probably 30-40 pounds packed. No problem. And it will fit on seat or rack.
I'll try to get a photo tonight and post it for you.
G'day ZoneIII, I hope these photos give you a pretty good idea? Notice I have a neck warmer around the back rest, this is to protect the stitching from the Velcro. This was an idea a mate had as he has the same bag and setup and found that the Velcro was damaging the stitching. Other than that it is great. Good Luck and let us know what you end up getting. Cheers
