Phalanx
.040 Over
Symptoms:
Last night, I went on a nice cool night ride and I noticed that when I switched my accessory lights on or off, or switched the main headlight to high/low, the oil light would come on for a little bit and then turn off. It did this every time I changed a light setting as in: Switch from high to low beam, it came on for a little bit...Switch from low to high beam, it came on for a little bit....Switch accessory lights on, it came on for a little bit, switch accessory lights off, it came on for a little bit...
Background:
I have 2200 miles on the R3T (2015) now, it had its' first service at the dealer exactly as required at 600 miles and went full synth when they did it.
I went out to do a grocery run earlier today and just out of curiosity, tested it again. Same behavior. Any switching of any light setting and the oil light comes on briefly and then goes out. Sometimes its' just a blink of it coming on then off, sometimes its' a second or two.
The oil light does not come on any other time (except of course for the startup sweep it goes through). After picking up some fixins for the grill, I took a detour and went downtown to some pretty crazy steep hills. The oil light didn't come on either up or down those hills either nor does it come on going around any kind of curve or banked curve (on/off ramps, even fast/steep ones).
I have no oil puddles where I park it. I've never seen any oil puddles where I park it at work.
The next thing is of course to go park it on a level spot run it for 30 seconds and then check the oil level but its' got me raising an eyebrow.
Anyone seen/heard of anything like this? Just some weird electronic gremlin creeping up?
Background:
