Sounds like the old girl is thirsty! You let her sit so long, her lips got sealed! If she tries to run on start fluid, then I'd say you have spark. I think you said you have never had the tank apart? Those rubber fuel lines inside the tank, deteriorate pretty bad. If you're not into tinkering, take it to the shop. If mine, I'd pull the tank off and change the filter and lines. Then I'd try to get all I could out of the fuel rail, and then fill the rail with carb cleaner before I connected it back to the tank. Fresh gas in the tank, cycle the pump a few times, and try it from there. Keep us posted, that's how we all learn.
